while using hd station i stopped all the bloatware apps and left the running apps manager in the background while using firefox. at the
exact moment the data issue kicked in , ALL THE BLOATWARE RESTARTED??? and when i restopped them in apps manager , they come
right back up. this can't be a coincidence , can it ?
Stop killing the bloatware apps. As you use the phone, it will load the apps you DO use and not load the ones you don't.
you HAVE to stop apps if you want to use the hd station and firefox AS ADVERTISED. if you don't you get an exceeded memory error and firefox crashes, (see attached picture).
stopping apps btw is what MOTOROLA (the manufacturer of the bionic and hd station) , tells you to do. unless your recommendation is to turn my hd station into a $130 paperweight.
also google books, maps and browser are the only apps i've ever used since i bought the phone in october
