need help with a messaging problem.
Well i deleted a thread of texts from someone while they were texting me i guess and one of the messages came through but i can not open it. NOw everytime i get a message it says have two unread messages, but there is only one to open. And sometimes i can pull down the notification at the top and there will be the message but i can not open it or delete it. How can i get rid of it? & turning off the phone and taking the battery out does not help. Please help it is reallly annoying.
Thanks
this same exact thing happened to me the other day, and i have no idea to get rid of it. Everytime i try opening it it just says loading... but never loads! and wen i pull down on my notification bar it says two unread but doesnt show the one i havent read yet! if you have figured it out yet let me know!
Deleting several message threads
Press HOME , and then tap > Messages.
On the All messages screen, press MENU, and then tap Delete.
Select the message threads you want to delete.
Tap Delete. Any locked messages will not be deleted.
Power the device off, then removed and replace the battery.
