- « Previous
- 1
- 2
- Next »
A screenshot of what shows on the pull down notifications would be helpful if you can post that....
I know very little about this, but while removing some apps on my husbands Droid, he asked me to remove that white bar, and I couldn't figure it out. I pressed on it clear to the right edge, held it and it disappeared....so far it's stayed away.
Having the same problem with my S10 plus. When I pull the notification bar, it disappears. After I pull it up, it appears again. You can also see that when the notification panel is pulled halfway. Seems more like a bug after the update.
msaimriaz, I want to make sure your device is working correctly. Does the notification appear to correspond to anything? Does it pop up when you get a certain type of notification or use a particular app?
MichelleH_VZW
My phone is doing this too and it doesn't correspond to anything or an app. It just stays there after I close and clear everything.
torilyn6, I am sad to hear you are experiencing issues with your phone. I know how vital it is for you to have a working phone. No worries, I am here to help. Did this occur after the most recent software update? Have you downloaded any new apps?
DiaS_VZW
- « Previous
- 1
- 2
- Next »
