Battery Life
shelbnicole11
I just bought the Droid Razr M, and I shut it off because it was slowing down, and then it would not turn on. I then plugged my charger in hoping it would turn on and it drained my battery. This has never happened before, help me!!
Thanks
Tags (3)
Re: Battery Life
Hello shelbnicole11
I'm very sorry your having an issue with your Droid Razr M. Let's work together and get this addressed.
Are you using the charger that came with the device? Do you have another charger to test with? Is there any discoloring around the charging port?
Please let me know so we can get you back up and running.
JoeL_VZW
Please follow us on twitter @vzwsupport
