Bluetooth does not work
BJGourlie
My Bluetooth worked fine with Ford sync and other devices. It just stopped working a few months ago. I don't know if it corresponded with a system update, but that's my guess. WiFi works fine.
Re: Bluetooth does not work
I know how beneficial bluetooth can be! We certainly want to see it up and running. Is bluetooth able to be turned on? What happens once bluetooth is enabled?
YoVZWT_VZW
BJGourlie
Bluetooth turns on, but the phone won't recognize any Bluetooth devices.
It didn't connect to the devices which were already setup and used to work,
Ford sync, a headset, and a fitness tracker. I deleted all the devices and
tried to start over, but it won't recognize anything.
On Tue, Jan 5, 2016 at 2:42 PM, Verizon Wireless Customer Support <
BJGourlie, let's start all over again. We're stepping in to help. Which make/model phone do you have? Did you recently update the software on your phone, update application software or download a new application to your phone?
LasinaHiVZW_VZW
BJGourlie
Great, I can use the help. It's a droid maxx running Android 4.4.4.
Bluetooth hasn't worked for months, so it's hard to tie it to a specific
update our app. It used to work fine, now not at all.
On Jan 9, 2016 3:12 PM, "Verizon Wireless Customer Support" <
BJGourlie,
Thanks so much for staying in touch with us on the forums. We definitely want to get this sorted out for you, so you can use your phone trouble-free! I took a look at the details for your phone and the 4.4.4 is the latest version, with that update having come in October 2014. There shouldn't be any issue related to any updates unless there was an application downloaded that has network control permissions around the time the issue began. The next best thing to do is restart the phone in Safe Mode and test it that way. This will allow you to rule out any software issues. To exit safe mode, a regular restart is all that you need to do. To enter Safe mode, please follow these steps: http://vz.to/1JxjPb0
EricW_VZW
