Recently (as in the last 3 weeks), if I use my Ford Sync to make calls, I cannot hear anything over the speaker and the person on the other line cannot hear me. I need to switch off of blue tooth to speaker or handset. I have had issues with a bluetooth headphones as well.
Using 9.18.94 operating systems.
Any advice?
Thanks for the suggestion... I had tried that several times and even pulled the fuse on the car to try to reset everything. However, in the end, I cleared the cache on the bluetooth and powered down and powered up the phone and seems to be working for the moment.
Have you tried deleting your device in FordSync and re-adding it? I use FordSync all the time and every time I update my ROM I need to do this. Hope this helps.
