Since going to Lollipop 5.1 on my turbo, I can only pair with one device. If I want to add another device, I must tell it to forget the first device and then go through the pairing process manually, anew, each time I want to use a different device. Anyone have a similar issue?
I appreciate those details! I would suggest testing the device in Safe Mode to rule out possibly third party interference. http://vz.to/1ENHmNr . If you still continue to run into an issue with having to autoconnect to your Honda. I would check with the manufacturer to review if there are any firmware updates currently available for your vehicle.
YosefT_VZW
Lets ensure we take a closer look into the issue, UTfan! To confirm, you're attempting to have two devices connected to bluetooth at the same time? Reviewing emulators for the device, you would need to "forget" to connect to a new bluetooth device.
YosefT_VZW
I am not an expert in the Bluetooth terminology but hopefully you will
understand my problem. Before Lollipop, I paired my phone with my home
phone (can answer cell calls on any cordless phone regardless of cell
location), my car, and my truck. When I was in the house, the phone, after
that initial setup, would automatically pair with the home phone. When I
got in the car, it would pair (after initial setup) with the car. Same
with the truck. I did the initial setup one time. Now, after downloading
Lollipop, I have to do the initial Bluetooth setup in the house and it will
pick up the house when I leave and return. But I have to tell the phone to
forget the house to pair (initial setup) with the car. When I return home,
I an having to tell the phone to forget the car and do initial setup all
over again for the home phone. Same thing when I get back in the car. It
will not pick up the car device based on the precious setup. It has truly
forgotten it and I have to repeat initial setup every time I move from one
device to the other--too much of a pain. Thanks for any help in advance.
On Wed, Sep 9, 2015 at 12:54 PM, Verizon Wireless Customer Support <
Thank you for those details and taking the time to clarify, UTFan. What model vehicle do you have? Often times after an update, the bluetooth profile/firmware may need to be updated to fit the new software on the device.
YosefT_VZW
I have a 2009 Honda Accord EX-L Navi.
Thanks for your help.
On Sep 11, 2015 2:44 PM, "Verizon Wireless Customer Support" <
YosefT_VZW
