Can The Nofication And Ring Volume Be Controlled Separately?
FMB10
Since the recent update the ring and notification volume show separate but move together. So either the notification setting is REALLY LOUD or I don't hear the phone ring. Is there a way to make them work independently again?
Tags (3)
Correct Answers
Re: Droid update combined phone and notification volume. Can it be seperated?
tikibar1
Sr. Leader
Sr. Leader
It's the way Google designed it for Marshmallow.
tikibar1
Sr. Leader
Sr. Leader
