Can my Droid Turbo 2 act as a storage device?
MIKELDENNIS25
Can turbo 2 act as a mass storage device for files other than media?
I want to save .txt and Master Cam files to SD card from my PC.
I was able to do this with my old razr.
Correct Answers
Re: Turbo 2 /mass storage device
Ann154
Expert
Expert
The option 2 should allow you to transfer any file to the device.
Ann154
Expert
Expert
How are you connecting the phone to the computer? Did you change the USB connection type from charging only to File Transfer? I have saved all sorts of files to my android devices.
MIKELDENNIS25
When I plug in to my PC the only choices are:
1. Charge phone
2. Transfer media files to computer
3. Transfer camera files to a computer
4. Connect as a musical instrument
5. Software installation
I also tried using a removable SD card, figuring that would be able to serve the purpose, but no dice with that either.
Like I said I used to be able to transfer any file type with my older droid Maxx
Ann154
Expert
Expert
