Droid Max phone
XRSCX012
I was charging the phone last night and now it wont turm on.
Does anyone know how to open this phone to remove battery or how to reset phone to come back on?
Re: Droid Max phone
Ann154
Expert
Expert
The battery is most likely to be not removable.
Re: Droid Max phone
tikibar1
Sr. Leader
Sr. Leader
Since the battery isn't removable, you might try an alternative to a battery pull, i.e., hold the power and volume down buttons simultaneously for 15-30 seconds and see if that reboots the phone.
Re: Droid Max phone
The battery is non-removable. Are there any indicator lights on the device while it's charging? Have you attempted hard power cycling?
TylerK_VZW
If my response answered your question please click the "Correct Answer" button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!
