My Droid Maxx gets hot and battery runs down too fast. How do I know what is running in the background that I don't need (and shut off) that won't affect the basic phone functions? I mostly use the device for talk, text, solitaire, and sometimes Facebook.
We want you to be able to utilize your device without the worry of burning your hands or the device dying in the middle of application utilization. Is your Droid MAXX currently on the most recent OS version?
HarleyE_VZW
If my response answered your question please click the "Correct Answer" button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!
Hi Harley,
I checked system updates and it says my device's software is up to date. It is Version 24.21.7.en.US.
I'm not sure if that is what you are asking. I'll give you the info I found under "About Phone."
System version24.21.7.obake-maxx_verizon.Verizon.en.US
Model numberDROID MAXX
System informationMotorola x8 Mobile Computing Syatem
Android version4.4.4
Android security patch level2016-04-01
Baseband versionMSM8960PRO_BP_23255.132.81.03R
Kernel version 3.4.42-g2730d20hudsoncm@ilclbld35#1Sat Apr 16 01:02:35 CDT2016
Build dateSat Apr 16:51:01 CDT 2016
Build numberSU6-7.7
I hope this helps,
Tim
