Can anyone tell me how to connect my Maxx to a television? Even Verizon support was confused. Thanks.
By Using an HDMI Cable if your TV has 1080P or 720P you can use that) Google Search HDMI Cable For your Model of Phone.. and that should get you the proper Cable.. b33
Follow this Link you can use this Cable.. http://www.amazon.com/Motorola-Standard-Cable-BIONIC-PHOTON/dp/B009YIZ03G
