Droid razor maxx update caused huge battery life issues
scottshaffer
I just updated my droid razor maxx to kitkat 4.4. The update went smoothly and the phone seems to be working well. BUT, the battery life is awful. I lost 75% in 3hrs. my phone used to have great battery life and now it's basically unusable.
does anybody have this issue or know how to fix it.
thanks
Correct Answers
Re: Droid razor maxx update caused huge battery life issues
scottshaffer
Hi, Thanks for  the reply.
I followed some advice on another thread... I changed the preferred network type to LTE/CDMA. I also think some of the battery life drain was caused by connecting and disconnecting from a wireless network I was near.
My phone battery has been fine in the past 2 days. Hopefully it continues that way, otherwise I'll come back here.
Thanks.
Let's get your device back in prime condition! Since the update may I ask if the device has been tested in Safe Mode? This help ensure that an app isn't causing an issue with your newly updated device. http://vz.to/1lO87Lh
YosefT_VZW
scottshaffer
Thanks.
