Droid turbo 2 bluetooth audio dropouts
camry9298
Anyone having issues with Bluetooth audio dropouts on the DT2? I performed all the remedies (Wipe partition/cache) unpaired/paired. I tried everything advised in the forums I visited. I also disabled wifi/Bluetooth scanning, same. Seems to be an issues since 6.0. Any one else with luck on this?
Re: Droid turbo 2 bluetooth audio dropouts
millerman61
I have found BT to better in general since the MM update.  If have you tried all other possible remedies, the only thing left to try that would be a factory data reset as painful as that might be,  I have found in my case that it worked when no other suggested remedies worked.
conhig
I tried factory reset and the stuttering on my Droid Turbo still comes and goes while using BT headsets or the system in my car. It's annoying. Sometimes turning of wifi helps, but not always. HELP
