HELP! ! ! ! SOL! ! ! ! Not ONE alarm/timer/stopwatch application will sound off on my Droid RAZR?
shill7891
What am I (or the device) not doing right????
Labels (2)
Re: HELP! ! ! ! SOL! ! ! ! Not ONE alarm/timer/stopwatch application will sound off on my Droid RAZR?
Not applicable
Try Settings - Sound - Volumes - Alarms
Customer Service Rep
I hear your SOS! Are you receiving any errors setting up your alarms? Are you using the default alarm clock? Also, in the alarm, check Settings there as well to make sure volume up.
MarquiaF_VZW
