Some how I got my phone set up for a blind user.... and I cant get it switched back. It wont scroll, and I have to tap the screen several times to get any thing to open at all.
https://asurion-verizon.siiguides.com/1122-droid-razr-maxx-hd/articles/105612-accessibility-features
I think this is what you are referring to in the link above.
Good Luck
For Voice an such go to > People or call settings > Dialer > then settings in your Dialer there you can un~check settings suck TTY mode, Hearing Aid, Etc.
One other thing you could do to clear the phone of this is Doing a Factory Reset..
