Help with upload message
I am having an issue with my phone, I keep getting a ,message that appears at the top left hand corner of the screen. The message says "13 items waiting to upload, remote computer offline, tap to continue" when I tap the message it disappears then reappears a couple of minutes later. Anyone have ideas?
Re: Help with upload message
No i haven't seen this issue) Do you have your Maxx attached to your computer? if so i would disconnect it.. you might try a soft reset and see if that clears up the issue) Hold power and lower volume in for 20 sec's.
Are you using MotoCast or something to sync with your computer? That's what it sounds like to me.
