Does anyone hear a clicking sound when on a phone call using a droid turbo?
Hi I talked to someone at Verizon today, they told me that it was not my speaker because the other party could hear the sound too. He did a hard reset at his location for the advanced calling and so far, keep fingers crossed, it is working fine now
Sent from my Verizon Wireless 4G LTE DROID
BranonShell,
That sort of noise would certainly be a concern to me! We want to make sure your phone works great. When did this start? Does it only happen on some calls or all? How often do you hear this during the call?
AndrewT_VZW
BranonShell,
Thanks for those details. Does this happen on all calls or just some of them? How often does this happen when on a call? We would recommend editing your post to remove personal details here on our public page.
AndrewT_VZW
Hi,
It is happening on all phone calls for the entire conversation. The speaker is working fine, I have tested that also.
Sounds like you've done some solid troubleshooting, Branonshell. I'm curious about something. Do you ever use a headset (either wired or Bluetooth) with your Turbo? If so, does this occur during those calls as well?
DionM_VZW
