It is kinda irritating to hear (loud and clear) "Verizon Wireless" before making a call AND when receiving a call, I have 6 or 7 friends and family that dont get this annoying announcement there MUST be a way to shut it off!
Look under Settings > Sound and see if Roaming Tone is checked; if it is, uncheck it.
TThis sounds like it's included in the stock ringtone. Have you tried changing the ringtone?
THANK YOU!!!!!
