How do I use Caps Lock?
garcia20
I can't get the keyboard to accept caps lock???
Correct Answers
Re: How to change keyboard
LENNYEDGE
Sr. Member
double tap ARROW on left side keyboard for caps. or go to input in settings and change keyboard type.
LENNYEDGE
Sr. Member
garcia20, ensuring all the features on your phones work is a must. Help is here. Awesome step to give LENNYEDGE. Are the other features of your phone working properly? Are you using the keyboard application that came with the device or a 3rd party application?
NatashaA_VZW
