I've noticed two very growing issues with my Droid Turbo that I need some help with. It seems that I continue to use more and more data every month even though I use WIFI most of the day. And the battery life on the phone is terrible. Any help on these is
rockton
Can anyone help me with data usage overages and short battery life with my Android Turbo?
Re: I've noticed two very growing issues with my Droid Turbo that I need some help with. It seems that I continue to use more and more data every month even though I use WIFI most of the day. And the battery life on the phone is terrible. Any help on thes
Salisbury
Sr. Member
   This is an interesting article I was reading awhile back from USA Today. It explains how a virus on a smartphone can cause data usage and effect the battery, I'm certainly not meaning the phone has a virus, but worth reading.
http://www.usatoday.com/story/tech/columnist/komando/2015/07/10/komando-question-and-answer/29907885...
Jakeman1
Sr. Member
Do you have all of the bloatware that you do not use disabled?  Do you use Facebook, Verizon Cloud or something else that typically uses a lot of data?
1) Disable any bloatware app you do not use
2) Change all of your contacts to google then disable Verizon Cloud and or Backup Assistant
3) change your Play Store settings to only auto download with a Wi-Fi connection
NJMagicman
Novice
Go into your device's settings and click on Data usage to see which app is consuming the data.  Then go into that app's settings to see if there is a wi-fi only setting.  It might be set to use the network instead of wifi.
