Well i finally went and Updated my First Razr Maxx to ICS yes i waited a Bit to Do it) but with the Jelly Bean Coming or came Out for a Lucky few till someone at Moto Pulled it.. I wanted to get both of my Maxx's Squared away for it so i Updated my First Maxx and all was doing OK till i noticed that i don't have any sound for my Keyboard when sending a Email or Text and i also don't have and Key sound for my Dialer which is Nice to have from time to time. So i tried a Soft Reset no that Didn't Work then i Tried a Clearing of the System Cache that didn't work either and i'm the one that tries to give a Suggestion but i'm stumped i guess i could clear all of my Apps or do the thing that ones have to Do Factory Reset Ugg.! so if any one can think of a Suggestion i would Appreciate it till then i will see what Grey hairs i can pull out of my head i'm getting old but not old Ha.! Thanks Again b33
Correct answers
It's the one with the yellow star next to it
Since you have two Maxx's, I assume you have gone down the settings and they are identical. That only leaves a Factory Reset. But on the other hand, as you know, after a Reset everything is pristine....faster....better.....and ready for JB. Have a nice day.
I don't have ICS but if I recall it's similar to JB. Try this.
Dialer > Menu > Dial Pad Touch Tones
Settings > Language and input > Select the keyboard that you are using (gear?) > Sound on keypress (Or Advanced > Typing & haptic feedback for Swiftkey Flow).
Try opening dialer - Menu - Call Settings - Ringtones and Keypad tones and make sure Keytones is checked.
Hey Guys thanks for the Responses back) And wildman i have settings that are kind of close to yours but not exact i wished they were i sent these two screen shots of what my Maxx's have i'm going to give a Few more things a try but i might have to Resort to a Factory Reset.. Ugg. wish me Luck b
Ginger's just mad that you've taken this long to update her.
For the dialer sound ... have you gone to system settings > sound, then checked Dial Pad Touch Tones?
For the keyboard sound ... as breezex said, have you gone to system settings > language & input > tap the gear to the right of Motorola input, then checked sound on keypress? Then you'll also have to set the Motorola keyboard as your default keyboard, i.e., language & input, press Default, choose English/Motorola Input.
Yea i know Now the phone is going to get even more ticked off at me i'm going to do the Dreaded F.D.R just the Basic though i'm not doing the Internal or SD card storage Hopefully that will work.!!!!!
Good luck!
I done the Dead Tik i got my Dialer back but when i'm in the Browser and i touch the Keyboard it Vibrates and you can see the letter or Number but it doesn't sound i know there should be a Setting to Kick it on one thing i Noticed is the Browser loads up Darn Quickly..
I hate noisy keyboards and want them all silent, myself, BUT ... if you insist on having sound when you press your keyboard (), then double-check your settings based on that post I left a while ago.
