Is anyone else having issues with their droid saying "Optimizing app # of #" and then doing nothing?
tmrocca
Droid turbo keeps getting really hot, turning off and trying to restart and it does nothing. Please help
Re: Is anyone else having issues with their droid saying "Optimizing app # of #" and then doing nothing?
Snn5
Sr. Leader
Sounds like you have apps on your phone that were not meant to be run on the new OS version.  You might try uninstalling apps one at a time and re-downloading, or the fastest method is to factory reset the phone and choose not to restore apps upon re-set up.  Then, go back to the store to your apps and download fresh installations.  That is one suggestion.
murda
that would be great if you could actually get the phone to work instead of continuously optimizing apps for 4 + hours
