Is there a way to get seprate notifications on Droid Razor m for email and text?
Randy33428
Re: Is there a way to get seprate notifications on Droid Razor m for email and text?
tikibar1
Sr. Leader
Sr. Leader
Have you looked in the settings for each of those apps?
Randy33428
yes
I don't see a way to turn on or off sound on gmail or text
Ann154
Expert
Expert
For Gmail it is: open Gmail > menu > settings > your gmail address > notifications check box is unchecked.
There are some additional notification options for labels too.
Randy33428
Thank you
