Issues with system update.
Lilleyjo
I just received a system update on my turbo phone, now I'm having issues with it. Everything is super slow. Games, FB, messages, and it's dropping calls. Anyone else having problems with the update?
Correct Answers
Re: Issues with system update.
bd94s10
Sr. Member
You can also plug it in to a computer and do the software repair assistant. It will ask if you want to backup your data and will restore it after it reinstalls. Repair Assistant - Software Upgrade Assistant (Motorola) | Verizon Wireless
Ann154
Expert
Expert
Have you tried a system cache clear through the recovery menu?
Lilleyjo
I did that, it hasn't helped.
Ann154
Expert
Expert
Factory reset then.
Lilleyjo,
Updates shouldn't harm your phone, they should make it better. When after the update installed did you start having trouble? Are all of your apps up to date in the Play Store http://vz.to/1q0D44z?
ShawnteJ_VZW
Lilleyjo
I haven't had a chance to do the factory reset, until now, which I will try. The problems started immediately after the update. Will the factory reset discard photos, games, or anything else that I've added since I bought the phone? If not, I will do the reset today and let you know if it fixes the problems.
BBBMoto
Yes, you must back up your data or it will be lost during FDR.
Lilleyjo, I want to make sure that your phone is working properly. Before you do the hard reset, have you downloaded any new applications? What is your zip code?
AmberF_VZW
Lilleyjo
I downloaded 3 new apps: Shelf life, Food Network, and In Season. Should I delete them?
Ann154
Expert
Expert
It can't hurt to try that first before factory resetting the phone.
