Low Audio Level after upgrade to Kitkat
rbtnt
Anyone else have a lower audio level on Notifications or on the audio jack on their Droid RAZR M?  I noticed some difference.
Re: Low Audio Level after upgrade to Kitkat
B33
Sr. Leader
Are you using any third party apps for your Audio,  I use the EQ app on my phone on your M if you use EQ you'll  have to disable the internal EQ that comes with the phone..  so there is no interference..
rbtnt Let's help get your volume working. Have you tried adjusting the volume in settings for notifications?
Sheritah_vzw
Follow us on Twitter
@VZWSupport
NikkiRAZRM
yes, having the same issue. Can't hear a thing anymore. I've tried every and adjustment possible.
B33
Sr. Leader
How about trying any Resets like power reset.!  Clearing of the Cache for the individual app that is causing the issue or you might try doing a system cache clear..
