Micro SD USB not accessible on PC side
Buddrock391
In the past I could connect my Droid Turbo 2 to my pc via USB cable and have access to both the internal storage as well as the Micro SD external storage. Since the latest update, I connect the phone to the PC via USB and I can only access the files in the internal storage. When I click on the SD card, it opens however it appears to be empty. Am I missing something? I know that the SD can now be used as internal storage but I should be able to access the files on the SD card.
Any help would be greatly appreciated..
