Mobile Hotspot Issue
Kbdrox
Razr Maxx, fully up to date. When I connect my pc to mobile hot spot it will connect for a few minutes and work fine. The pc will then stay connected to the phone but will stop displaying web content. I can ping out to, say, yahoo.com and it comes back showing a good connection. When I then try to connect to a website with the phone's browser it won't connect either. To make the phone work again I have to either reboot or switch to airplane mode and back to reset the phone's radio.
In settings I have reset APN to default which did nothing to help the problem.
Thanks for reading.
