Motorola backup battery - output ports
RDSIGRIST
It is assumed that the output of the backup battery will be the RED usb wire wrapped around the battery pack.  Can the standard USB 2.0 port be used as an output?  I would like to power a small LED lamp that has the standard USB port.  I could use a mini-USB to standard USB 2.0 converter, but not sure if that will transfer power to a small LED lamp that has a plug for the USB 2.0.
Re: Motorola backup battery - output ports
RDSIGRIST, that's a great question, and we definitely understand wanting to be familiar with your device! In this case, we would recommend contacting Motorola. We want to make sure that you receive the most accurate information regarding your device's USB port charging options.
Motorola's contact options can be viewed here: https://motorola-global-portal.custhelp.com/app/mcp/contactus
Please let us know if this helps.
LauraF_VZW
