My Droid Razr will not power up
zetagp
I have had my Droid Razr 32gb for 2 years and I have been having problems with it lately.  When I shut the phone off to stop the Back up assistant from CONTINUING to work, it will not power back on.  I've tried plugging into the laptop to charge (it was fully charged prior to shutting off).  I have held down the power button and the volume down button MULTIPLE time for 10-30 seconds and it will not power on.  Please help. I need my phone.
Correct Answers
Re: My Droid Razr will not power up
I'm sorry to hear that you're having issues with your phone zetagp! Please follow these steps to attempt a Hard Reset on your device. http://vz.to/1qGxCzd
If it still will not power on, we can explore opportunities for replacement.
Thank you,
MichelleH_VZW
Thank you,
MichelleH_VZW
SoccerRef12
Sr. Member
You probably need to freeze/disable BackUp Assistant when you get your device back up and running. BUA sucks. Use Google to back up everything. As far as turning on your device, try holding down all three buttons, Power Vol + and - for about 15 seconds. That should start up your phone.
