My device crashed and won't turn on. How do I power it up again?
Seasickfishy
I Don't know what happened to it. I'm also having the problem of calls going straight to voicemail.
Tags (3)
Correct Answers
Re: Was using the maps feature, it crashed and then my phone went black and won't turn on now. :-(.
tikibar1
MVP MVP
MVP
Have you tried holding the power and volume down buttons simultaneously for 15-30 seconds to see if that reboots the phone?
tikibar1
MVP MVP
MVP
Seasickfishy
You are officially my hero. That worked.  i'm so used to phones where you just pop the battery out and pop it back in. lOl. Thank you so much!
tikibar1
MVP MVP
MVP
You're welcome; that key combo takes the place of a battery pull when the phone is sealed like the Turbo.
B33
Sr. Leader
Pressing just the Power button can also do a Reset as well...  I added some additional things that can help if your phone is giving you issues in the Future..
The first link from Motorola is for re-setting and then for doing a F.D.R. the second Link is for clearing the cache if you need any additional help just let me know.. Happy Holidays b33
Reset my device
Clear Cache Partition
I added this Link if your having issues with 3rd party Apps:  Safe Mode
What is safe mode and how do I use it ?
