My droid turbo charger won't remain in place while I charge.
ALEGOM29
A few days ago, I plugged in my charger and it wouldn't lock in place.  I've tried cleaning out with a toothpick to get rid of lint, but that didn't solve the problem.  Any ideas on what I can do?
Re: My droid turbo charger won't remain in place while I charge.
ALEGOM29, having the phone and charger working properly is important. Are you using the charger that came with the phone? Do you still see debris in the charging port? Check here for indications of liquid/physical damage http://vz.to/2jZZxNg.
TionnaB_VZW
ALEGOM29,
A phone without power is like a fish without water - it works for a while but we'd always want to get it back where it belongs. Normally a charging plug should fit snugly into the phone without any wiggling, similar to headphones plugged into something. Have you tried any other chargers on the phone to see if it's still loose (make sure the plug matches the phone first)? Was there a lot debris inside the charging port when you checked it out?
RussellM_VZW
