My phones gets too hot sometime I feel like it will overheat or burn a hole in my pocket.
mrhillnc
Re: My phones gets too hot sometime I feel like it will overheat or burn a hole in my pocket.
MiiHere
Leader
Do you close all apps running in the background?
clg92
Novice
What make and model phone do you have?
MiiHere
Leader
It's a Droid MAXX
mrhillnc
Yes. Sometime it will get hot shortly after a restart. I'm normally in a
good reception area with WiFi on so what could it be.
MiiHere
Leader
How do you close your apps when finished using them? Having wi-fi will create a bit more heat, much like when you're using your location to use the GPS.
mrhillnc
I normally back all the way out. I also have a battery saver app. That
closes any unused apps. Maybe it's the GPS
mrhillnc
Yes sometimes
