PATCH/FIX FOR POOR 4G LTE SIGNAL STRENGTH AFTER MARSHMALLOW UPDATE ON DROID TURBO 2
K_0274
When will a patch / fix be available for the 4G LTE signal strength issues that occur after Marshmallow update. Since "upgrading" to Marshmallow 4G LTE signal strength has been horrible and inconsistent (radio installed?). This is after had reset, clearing cache, network reset etc. Unacceptable IMHO.
Labels (2)
Re: PATCH/FIX FOR POOR 4G LTE SIGNAL STRENGTH AFTER MARSHMALLOW UPDATE ON DROID TURBO 2
Customer Service Rep
You deserve great service wherever you are! We are here to help. Did you previously have stronger signal where this is currently happening? Does this happen on any other Verizon phones in that area that you are aware of?
JosephT_VZW
K_0274
Yes I previously had stronger 4G LTE Signal when running the stock Android lollipop 5.1 OS on Turbo 2. It was only when I "upgraded" (downgraded) to Marshmallow (6.0) that signal strength is now inconsistent, spotty and 3 bars at best (on Lollipop had 5 bar coverage consistently). Verizon does not allow you to revert back to previous OS so I'm hoping your developers are quickly working on a patch (6.0.1) or customers will switch to other networks! IMHO
