Problem ordering accessories
DogwoodAcres
Is Droid Turbo 1254 different than just Droid Turbo?
Re: Problem ordering accessories
Ann154
Expert
Expert
It should be the same device. The only thing I would be concerned about it is the ballistic nylon version is slightly thicker then the standard black model xt1254.
