WIFI and Bluetooth will not turn on, DROID MAXX
imagic5
I Am having the same problem.  For a couple of months already my wifi has been spotty and now I haven't been able to get it working at all!
all of the research I've found suggests that, just like what many others have said, it is a software update issue.
BUt what can i do in the meantime?
pplease advise.
Tags (2)
Re: WIFI and Bluetooth will not turn on, DROID MAXX
KathyH_VZW
Verizon Employee
We want to give you back the ability to customize your network options, imagic5. To confirm are you also using the Droid Maxx? What exactly happens when you attempt to access different WiFi networks? Can you confirm the current system version via Settings>About Phone?
YaleK_VZW
imagic5
Thank you Kathy!
Specs:
System Version: 24.3.7.obake-maxx_verizon.Verizon.en.US
Model Number: Droid Maxx
System: Motorola X8
Android 4.4.4
Build Number: SU6-7
Is there anything else I can provide you with? I'm eager to have you work with me.
Thank you for replying to my post.
- Ian
