Why Do My Droid Turbo 2 Phones Have Volume Problems?
RAPIDDAGGER1
Two of our DT2 phones received the update 25.11.10.en.US and both immediately incurred the same issue, ascending volume on all ring tones,notifications and even incoming callers voices! Verizon replaced one phone and 3 weeks later it got the same update and now it to is screwed up. Nobody has solution! One Verizon tech said it is built into the Nougat software,so I called Motorola and they basically said tough [Removed] and THEN I called Google tech support and they threw their hands up! What the [Removed]? Verizon says there is nothing they can do so now I own two[Removed] DT2s, should have stayed with APPLE.  Has ANYONE heard of solution???
inappropriate content removed as required by the Verizon Wireless Terms of Service
Message edited by Verizon Moderator
