My razr maxx hd battery will drain out in just a few hours, so I have to keep it plugged in most of the time. I can't figure out what is draining it out. Has anyone had similar problems?
Red74,
This sounds alarming that your battery is dying so quickly. Please go to your Settings/Battery. This will provide you what is using your battery the most.
RobinD_VZW
Red74,
RobinD_VZW
