Why does my Droid Turbo 2 answer when my Vonage phone rings?
Ban_Adryl
My Vonage (VIOP) phone is connected to my wireless router. When one of the wireless phones connected to that router rings, my Droid Turbo 2 also rings and I can answer on either. My Droid is connected to my wireless router wifi at home to save on data. Vonage has call forwarding turned off. Is there a way to stop this cross talk ringing?
Correct Answers
Re: When my Vonage (VOIP) phone rings, my Droid Turbo 2 answers?
Ban_Adryl
Yes I do have the Vonage extension app installed. I think I found a setting that will fix that under incoming calls. Thanks a lot. I am new to smart phones, so some things do not occur to me.
Ban_Adryl, thanks for bringing this to our attention and we certainly want to get his issue with your phone ringing resolved. Is there a Vonage application installed on your device?
GersonG_VZW
Ban_Adryl
