Why does my droid turbo not connect to wifi at work but will connect at home?
fnotlc070496
I set my turbo up on my wifi at home and it works there but when I am at work, it will not connect. It see the wifi network and tries to connect but will not. I have entered all my passwords for the wifi at work but a not go. Help! I would like to be connected so I will not use my data.
Correct Answers
Re: Why does my droid turbo not connect to wifi at work but will connect at home?
SuzyQ
Sr. Leader
Sr. Leader
Perhaps your work wifi has restrictions on devices that are allowed to connect?  Can you check with your IT department and see if they are filtering MAC addresses or otherwise restricting who can connect to their wifi?
Have you connected to the work wifi previously, successfully?
SuzyQ
Sr. Leader
Sr. Leader
