Why doesn't my phone ring for priority contacts?
Pavlov1901
I have a turbo 2 that updated last weekend. I keep my phone set to priority only for calls and texts. Since the update my priority contacts either don't ring or ring part of my tone then stop. I'm missing lots of calls and texts because of this. I've played with the settings and nothing. How do I get this fixed?
Labels (2)
Correct answers
Re: Update
Ann154
Community Leader
Community Leader
Try going in the Moto app or the sounds and notifications setting and verify the settings or reset them.
Re: Update
Ann154
Community Leader
Community Leader
Re: Update
Customer Service Rep
Pavlov1901,
Software updates enhance the device so it saddens me to hear that this did not occur. Lets get this fixed. What is the current software version on the device? Go to settings>about phone>s/w verison. Have you powered the device off/on since the update?
Thanks,
PamelaF_VZW
