Why is my Droid Turbo battery suddenly draining so much faster than before?
lanunz
Why is my Droid Turbo battery suddenly draining so much faster than before? It's only 4 months old. I'm using the same (very few) apps, making no more phone calls, sending no more text messages, yet the battery doesn't last half a day. Any advice would be greatly appreciated!
Re: Why is my Droid Turbo battery suddenly draining so much faster than before?
SuzyQ
Sr. Leader
Sr. Leader
Go to settings >> battery - what are the top 3 on the list and what % are they?  Post that and we can investigate further.
lanunz
The top 3 are Cell standby 2%, Ring (video doorbell) 1% and Android OS 1%.  Thanks!  It also says "approx. 17 hours left" but I doubt it based on the past few days.
SuzyQ
Sr. Leader
Sr. Leader
Not much to go on there.  When the battery DOES drain as you are expecting ti to do, then tell us what the three big users are?
