Why is my ringtone and notification volume adjust together?
hetz6366
Since the upgrade 2 versions ago, I can not individually change the ringtone volume and the notification volume, they move together. How do I fix this?
Tags (1)
Correct Answers
Re: My ringtone and notification volume adjust together. I cannot set separately.
tikibar1
Sr. Leader
Sr. Leader
That's how Google designed it.
tikibar1
Sr. Leader
Sr. Leader
hetz6366
They used to be separate until 2 upgrades ago!
tikibar1
Sr. Leader
Sr. Leader
Correct; Google changed it with the Marshmallow update.
