Why won't Pandora work over 4G?
Blast338
I have full bars and plenty of data on my Droid Turbo. Pandora will not play unless I am connected to WiFi. Tried everything I could find using Google. Hope you guys can give me something new.
Correct Answers
Re: Pandora not working over 4G
Blast338
Checked that and background data was enabled. However I disabled it then re enabled it and presto. Pandora is working again. Thank you.
Snn5
Sr. Leader
Background data is enabled for that app in the Data Usage screen in Settings?
Blast338
Snn5
Sr. Leader
Sometimes all it takes is a toggle off and back on.  Smiley Happy
