Why won't my device recognize my SD card?
Hollywell
When I put in my SD card, the turbo no longer recognizes the SIM card. How do I fix that?
Correct Answers
Re: turbo 2 SD installation
nicholas_g
Novice
Make sure they are both facing the proper way and are seated properly. If either is not seated properly it might prevent the sim from making contact with the pins inside the device that make contact with the sim card.
Ann154
MVP MVP
MVP
Did you put both the SD card and the SIM card in correctly?
Hollywell
Yes.
DrPJ
I have exactly the same problem. Were you able to fix it?
nicholas_g
Novice
