Will Droid Turbo work abroad
yager05
Hello,
I am interested in Motorola Droid Turbo. I wonder will the phone work in Europe.
Due to my business I spend a lot time in Europe. It supports nano SIM if I am correct, but I am not sure will it work with European operators.
Could you please tell will it wotk or not?
Thank you
Correct Answers
Re: Will Droid Turbo work abroad
yager05
Thank you.
I am also positive it will work in Europe, only LTE is questionable.
I hope someone from Verzion will answer here.
B33
Sr. Leader
The Phone will be available on the 30th of this month unless something changes but the Best thing to do is Contact Verizon Global Services Let them Look over your account and set the phone up to were it can work in your Area's of Travel.. Have a Look at my Thread here for more Info on the phone..
Go to the Last Page for the Latest Information.. b33
yager05
Thank you for your answer.
I am planning to buy it off contract so I doubt there will be any additional settings to my account. For example, Droid Ultra worked fine in Europe.
I am asking mostly for Croatia. Their frequencies are:
2G – 900 MHz and 1800 MHz
3G – 900 MHz and 2100 MHz
4G – 800 MHz and 1800 MHz
On GSMarena I have found 2G frequencies for Turbo, but not for 3G and 4G.
B33
Sr. Leader
Hey Cool I hope to get one off contract as well just before or after Christmas..
yager05
So I have found Droid Turbo bands.
Networks and Bands
CDMA/EVDO Rev A (850, 1900MHz)
LTE Cat 4 (bands 2, 3, 4, 7, 13)
Carrier Aggregation (B4+13)
GSM/GPRS/EDGE (850, 900, 1800, 1900MHz)
UMTS/HSPA+ (850, 900, 1900, 2100MHz)
So it should work normally. Only qeustion is 4g/LTE. Dont know what bands 2,3,4,7,13 means.
B33
Sr. Leader
I'm Guessing the phone will be able to cover Quite a Bandwidth only time will tell more and it probably wouldn't hurt to take a peek once in while in at Droid Life, or Android Central, Phone Scoop for the Latest news.. or I'll try and put what i can one here.. through there Links
tbo27
Sr. Member
I'm gonna go out on a limb and say yes it will work in Europe
yager05
Thank you.
tbo27
Sr. Member
If you're ultra worked fine I see no reason the turbo shouldn't. They like $. Thanks b33 for all the info sent out about it. Enjoy Droidlife I do
B33
Sr. Leader
I sure Like the 64GB Version with that Little Plague on back of the Battery Cover.. Looks Very Cool and should have plenty of Room to for just about anything you want to put on it..
