after kit kat update Bluetooth and WiFi don't work together
mikeSOgood
Motorola Droid HD wifi doesn't work if bluetooth is on.Turn bluetooth off wifi works.started after KitKat update.I would like to use my bluetooth and WiFi because Verizon too expensive.or I'm going to change my service
Re: after kit kat update Bluetooth and WiFi don't work together
Not applicable
The update not coded by Verizon caused the issues you are having.
Contact Motorola and have their support people fix it.
Verizon cannot fix the Google-Motorola update.
Good Luck
