anybody having sudden charging issues with droid turbo
KILLAMYTOLLU
three days ago i plug my droid turbo in to charge and ever since then the phone will not charge more than a quarter way up on the battery symbol displaying amount of charge on the phone currently. Tried turning it off for a few minutes, all night, and nothing still will not charge more than a quarter way. checked for update , says system is up to date. Figured i would ask in here first before i call customer service. Anybody dealing with this or similar issues charging or with droid turbo (32g)??
Re: anybody having sudden charging issues with droid turbo
I'm so sorry you have been having these charger issues with the Turbo. Let's look into this together. Is the device damaged? Have you tried a different charger? If so, what were the results?
JoeL_VZW
I rely on my phone to function properly at all times and definitely want to make sure that you have a phone with a working charge, KILLAMYTOLLU. Let's look further into this and make sure your phone gets a full charge. Please complete a device health check to check on any issues the device may be having, http://spr.ly/65858W3bN. Has there been any damage to the phone or charging port? Are you using the charger that came with the phone?
DanielleR_VZW
Milow3333
Hi I have the same problem, but the screen was to static then flickering battery guage drops to zero, and i had it on rice most of the day, it was slightly water damage on its right side the other day... Smiley Sad
Milow3333
@Verizon : I tried two different cords, and chargers, the long usb i have, that I recently bought to transper, from my phone to comp. Will not work, but right now I turned it on tried to FDR and still nothing, but just two static screens back to back, i am putting it back on rice, this makes it around 10 hours on rice. It was water damaged, but I pulled it out of the water, put it on a pinao, i wonder if accustics can make the liquid move a lot to really do some damange on it...
Milow3333, these sound like serious issues and we want you to have a working device. I would like to look into replacement options with you. Please respond to the Private Message I have sent you.
MahrizaM_VZW
