battery drain issues since security update?
kflin01
Anyone having a Battery rapidly drain then suddenly shut off at 15% after the security update they just did? Going from 100% to 15% in a matter of hours with almost no usage or apparent background apps running.  Shuts off like battery is dead but once the phone is back on a charger it starts charging at 15% again. None of these issues before the security update a couple days ago.
