So I'm on day two of owning the turbo and it seems like my battery life isn't very good. Today I had my phone off of the charger for about 90 minutes and I'm already down to 92%. My galaxy s5 wouldn't be this low by now. Any suggestions on what could be causing this??
Have you checked the battery usage graph to find out what is using the battery?
So after a few days it seems that its always the display that uses the most battery. I'm starting to think I might have a defective unit, it seems that now the moto voice opens up whenever it wants.
As I pointed out on your other thread you started clear your moto Voice settings the cache then retry doing the Voice command in a Quiet Room.. if your still have issues you can Disable it as I have with my Device..
And Give this App a Try it will tell you allot of what your phone is doing all the apps the phones CPU's the Temps and of the battery and CPU it works well and I have been using it for many years on my Droid Phones
System Panel App it is in the Google Play Store or Visit it Via this Link..
SystemPanel App / Task Manager - Android Apps on Google Play
